Hello gentlemen,
I'm in the process of wiring my Walbro Fuel Pump and I am at a point where I need to make some decisions.
I've been looking at fuses and relays for the fuel pump re-wire, the fuse type I've found locally was the Bussmann - ATC Splash-Proof Fuse Holder #12 Lead Wire, 30A Max.
http://www.cooperbussmann.com/pdf/95fa462a-7aa0-4d18-a094-cff814dd6e1a.pdf
Will this be sufficient?
From Shaeff's write-up, he suggested using a 10gauge wire, the Bussmann uses a 12gauge. In addition to this difference, the Bussman fuse is a Fuse holder type versus the in-line type Shaeff suggested.
With the previous statement in mind, what fuse should I use for the fuel pump if the fuse holder is ready for the job?
Thank you,
Matt-
Thank you,
Matt-
