Im about to upgrade my fuel pump and had a few questions. First which pump is better as an upgrade? The Walbro 255lph or the mk4 Denso 280lph? If i were to install the Mk4 pump, would I have to do the 12Volt upgrade as well like the Walbro?
with my considerations of pro and con.
I decided MKIV for reliability, no chance of Chinese Walbro,
and as jdub stated, it draws more amps and routes through the 15amp efi fuse
but as some documentation shows denso can draw up to 21amps.
To be clear; My research and decision to do 12v rewire because of amp draw is only concerning the MKIV pump.
I did not research the walbro in that respect.
With a rewire (10ga optimal) there is less resistance and more output. More strands = better current. This will guarantee sufficient power supply to factory pump or aftermarket. When Fuel Pressure and load is put on the pump it needs more power, and if your wire can't supply the needed power it burns up. On a note if that pump draws 15 amps WOT and that 22ga wire can't supply it consistently , you've got problems.
