Fuel Problems
Status
Not open for further replies.
NewGen
799
Norwalk, IA
Alright I resently purchased a 1988 toyota supra 7mge. It hasnt ran for 2 years. We put a new starter, plugs wires, Intake manifold gaskets, New battey, fuel pump, fuel pressure regulator and we have the fuel pump relay bypassed right now because its bad. The car will start and idle fine but as soon as you lay into the gay at all the car will instantly die. Does anyone have any idea on what it might be?
matt
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
matt
How did you determine the fuel pump relay is bad? Have you checked for error codes? Tested the AFM?
Wow... now THAT's a typo!!!
CRE
Oct 24, 2005
3,485
Denver, CO
AJ'S 88NA;1058849 said:
Hope it's a typo:)
I'm sure it is... if it wasn't he'd be bragging about how his MKIII was the lightest MKIII on it's feet and complaining about the flaming tailpipe. :evil2:
Disclaimer: Absolutely no offense was intended in this post.
Kckazdude
1,239
Memphis, TN
matt
Maybe the car is standing up for its gay rights?!? :aigo: :biglaugh:
Seriously, check the AFM.
NewGen
799
Norwalk, IA
lol thanks guys. that was a typo but its really funny so i'm not gona change it. the pumped was seized. How do you test the afm?
NewGen
799
Norwalk, IA
lol I have a turbo supra this cars actually my cousins so bare with me :) I know how tempermental they get. Any change a 5m maf will work lol
CRE
Oct 24, 2005
3,485
Denver, CO
There are a few other valid considerations mentioned in this thread which you haven't acknowledged checking... So, if you would be so kind as to recap precisely what you have tested it'll make things a lot easier for us to help you.
NewGen
799
Norwalk, IA
Replaced fuel pump, Fuel presure regulator, Fuel pulsation dampiner, Tested fuel pressure and its fine, Swaped mafs. Thats it. Its not throwing any type of code
matt
AJ'S 88NA
2,419
Florida
Have you checked the timing per TSRM? Did you check the MAF per the TSRM? Sure you don't have any vac leaks, air leaks around the MAF or TB? If it sat for a while changed the fuel?Compression test?
If you post back and say "I think it"s OK, or it should be alright" there's going to be a few that will be done with this thread, me being one :)
NewGen
799
Norwalk, IA
wow since when did everyone on supra mania turn into an asshole... I'm not even gona bother its not my car anyways... By the way its common sense if the cars sat for 2 years to drain the tank and replace it and all the above has been done thought that was just a standard tune up...
AJ'S 88NA
2,419
Florida
Did you post that? Also common sense to check all the things I mentioned, you should have said what you've done and what you haven't. Not trying to be an asshole but if you don't give us something to go on we are just guessing like you are throwing parts at it.
Status
