I'm keeping log of everything I do, as well as pics. And the whole thing about the misfire and jerking, it will only do that under boost no matter how many psi, 1psi or 6 psi. As long as I drive it without boosting it's fine. Response well and everything... IDK, I'll just to keep on going and I'll let you all know what I find...
---------- Post added at 10:43 AM ---------- Previous post was at 10:29 AM ----------
That is one of the first things I replaced when I started to have this problem...as well as the checking and replacing the spark plugs,testing the coil pack,looking over all the vac. lines and wiring as best I could see,air filter,oil change,A340E filter and B&M fluid with a B&M AT cooler,Royal Purple Diff. 80w90 fluid,New OE radiator,that included a good flush and clean,(with out taking the engine out and doing it that way). And when I got it there where some heater hose's that where leaking ,so I ordered the Mishimoto heater hose kit...just have not put them in yet,while I was waiting for the mail I got heater hose from OReilly's.
I know most of that probley has nothing to do with my current problem, just letting you know what I have done so far...
