fuel problem please help
too_stand
83
Campton Kentucky
I have an 89 Supra Turbo that I recently changed motors and am having trouble getting it going. First let me explain it has a 57 trim turbo and a walbro 255 fuel pump. Upon initital start up I had a Lexus AFM but kept getting the 31 engine code so I switched back to a stock afm to see if it would run better. The engine idles well now and throws no codes, but it will not take gas. When you try to accelerate it bogs and chokes off.Every plug in and innercooler connection have been carefully checked. It is timed at 12 degrees, does any one have any ideas why it wont take fuel?..thanks...
mkiii88supra
93
PA
hey man i have like the same problem you have with the same mods. i have codes 31 and 51 and if i leave the codes on the car runs but ones it hits boost it looses power but if i clear the codes it seems to flood or get no fuel at all. i have a lexus AFM but i think my AFM electronics might be messed up idk no one gave me an answer either when i posted up the other day.
