fuel line impossible bolt
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
Poodles;1086318 said:
It's sealed with corrosion...
Spray it with PB Blaster, and WALK AWAY. Let it sit overnight even...
Shytheed Dumas;1086351 said:
^^ This and a vice grip.
^^^ Agreed. Since you pretty much rounded off the nut, go after it with vice grips; and then once you got it apart, you can figure out what you need to do to correctly reinstall the new line.
BTW, if the nut that's rounded is the nut on the hard line, then correctly means:
1. Replace that 6' of hard line with new line.
or
2. Cut the hard line back just a little bit, and pull the rounded nut off the hard line. Get a new nut, and put it on the hard line; then flare the end of the hard line with a flaring tool. When you're done it'll be good as new.
supramang
74
Farmington
alright well if your gonna pull the motor and this section of line is being a pain, I guess i would suggest taking the top banjo bolt out of that connector on the side of the engine. then unbolt the bracket from the engine so you can leave the bottom banjo bolt connected. Then once you get the engine out and everything you will have more room to fight with this line. But i dont know which of you are actually in the process of pulling the motor.
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
ok so i got fed up today
got a tube cutter
cut the hard line
and put a compression fitting on there and attached it to the steel braided line
and im all done :]
