Fuel kut do to MBC... Time for AFPR???
str8_6
master yuepeng
Mar 14, 2007
241
wa
to the op, you are going about this situation ALL WRONG. dont go replacing parts that you "think" are wrong.
first off route your wastegate BACK TO NORMAL....go WOT and make sure it is running good. if everything boost fine, boost holds good, i would not worry about your waste gate being the problem at this time.
now please draw us a diagram of how you have your mbc hooked up? i have turbo smart manual boost controller also and it works awesome.
if i were you, i would start off with at least safc and wideband.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Evilempire1.3JZ-GTE Thank you so Much!!!
I have the MBC hooked up exactly likr the one in the picture... I will push on my WG's tomorrow....
Thank you Guy's SO MUCH for the help!!!:biglaugh:
