OK so i got everything together and my car won't fire it cranks and you can here the exhaust burping but no cigar.
Fuel pump turns on with Fp and B+ jumped also seeing almost 40psi in fuel pressure.
I have aftermarket fuel injector clips (EV6 i think) and 560cc injectors off a evo 8.
I think the culprit is when i switched them from my old harness to new harness i messed up the wire pattern.
Only other thing that it could be is the CPS i think. i am using a Green Plug CPS(Yellow Plug Harness) on a Grey Plug Harness. Without trying to switch the wires around at all.
My car is a 1989 Turbo Grey Plug Harness.
Injector Clip 1 (Stock Grey clip) - White/White with black stripe
Injector Clip 2 (Maroon) - Black/White with Red stripe
Injector Clip 3 (Grey) - Red/White
Injector Clip 4 (Maroon) - White/white blue stripe
Injector Clip 5 (GRey) - White/Red
Injector clip 6 (Maroon) -Black/White with Red stripe
Can someone please confirm the order with me and help me figure out witch wire goes on the left and witch wire goes to the right of the clip.
Thanks in Advance the help is appreciated tons.
