Fuel door...
Doward
4,245
Alachua, FL
Is the fuel door supposed to have some sort of spacer on the back side of it, where it bolts to the body?
I ask because I've now seen the 6th MKIII Supra that has the fuel door scraping along when you open it.
2 tiny flat washers later, and it's centered nicely and no longer scrapes - works like new again!
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
I just kinda bent mine a little bit... now it sits perfectly aligned and no longer scrapes... seems like after 18 years of opening and closing it got a little bent outta shape.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
worked great :) no more scraping fuel door for me! And it's aligned a lot better, I noticed part of it went in further and wasn't aligned with the body, I bent it to correct that and found that it no longer scraped as well!
I chose to bend it rather than re-align it because I could tell it had never been tampered with and somebody probably just rested on it whil fueling or broke their fall with it so I decided to bend it back.. worked out perfect.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Mine kind of sits 1/2" deeper than the body, and the lever doesn't pop it open really, i gotta pop it out with a key usually after i pull the lever.
ToyoHabu
261
Huntsville, Alabama, United States
what most likely has happened is that at some point over the years the fuel door was shall we say over zealously opened thus bending the hinge a bit and putting the whole thing out of whack. I have had both symptoms of this, scraping metal and having to ask strangers at gas stations to open my gas door while I am pulling the door lever. :nono: of course it was the previous owners fault:icon_razz
Doward
4,245
Alachua, FL
Damn... For all you guys with the scrape going on, just unbolt the fuel door, use one hand to hold both bolts in place, and turn it over - put a thin flat washer between the door and the body, and presto - instant total win.
My door opens completely, with no scraping, total ease, and pops perfectly!
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
The first night I had my car I went to fill up and couldnt get it open, luckily a friend was with me.
After that I learned my cell phone was perfect size to shove under the lever while i open the fuel door.
billspreston01
555
North Carolina
HAHA...this is hilarious. I've done they old "hey, can you help me real quick" at the gas station before. I used to shove a rag under the lever and cary a screw driver in the center console. I eventually got it to work (shaved a little material off the little black nub that goes in and out). It's still a b**** sometimes.
