any suggestions for my mods ?
1jzgte
gt35R t4 split pulse duel ball bearing 70ar comp 1.06 turbine
hks 555cc high impedence side feed injectors
walbro 255lph 600 hp ready
4 core 12x24 fmic
3" cat back no cat
anything else am i forgetting maybe a gm map or 2jz map ? to get more then 1 bar
i am looking for a tunning solution that haves several things built into one
i want a 3 preset system that controls my map sensor reading yep i dont have to deal with maft at least and also montors and adjust my wide band o2 then finaly this modual also should have a boost controller and maybe other functions such as e fan turn on and turbo timer would be nice all in one packages! i need help on that part the electronics but i want it all under three + things it manages all under 3 presets
1 preset for commuting cruising to work like good milage soft tune and low boost level
2nd preset for auto x or canyon carving advance tunning little for faster more linear spool and have moderate boost about 14.7psi
3rd preset for drag racing need not say more tune boost up to 22-24 psi when drag racing but i have to add a top feed rail and higher injectors for that probley 700-750cc injectors since ill probley peek my turbo at 22-24 psi at 7500 rpms at around 700hp
is there anything i am missing on my set up other then a little spray here and there maybe a 4th preset option? i dont know any recomendations ?
1jzgte
4 core 12x24 fmic
3" cat back no cat
