Fuel cut with gt35r
zurud
351
Evansville, IN
Code 34 is fuel cut. When you hit fuel cut you will get code 34. Disconnect the battery or pull the ecu fuse to eliminate it. If you hit fuel cut again it will show up again. Is this the first time you hit fuel cut?
nick rossow
florence, ky
I am getting about 35 hz at idle. Yes I have hit fuel cut before. I have a few ideas of what to check next that are long shots. Hopefully I can find what's wrong.
