Story: so I'm still for some reason hitting fuel cut. I had installed a ddp, and figured I would still hit fuel cut w/o a bigger fuel pump. I was running stock. And yes I did hit fuel cut.
I never turned up the boost, it turned itself up I noticed, 16psi is where it's at now. It was at 9 when I had the stock elbow and 3 in dp.
So I go and buy a 320 lph aem fuel pump. I still hit fuel cut.
Why is this? I figured it would've gone away.
My mods:
57 ct26
560 inj
Lexus Afm
Afpr set to 40
320 lph fuel pump
J tube delete
3in turbo back, cooleze dp to cat to tanabe medallaion
2.5in ic upper cooleze piping
Spearco ic
Hallman bc
Hks ssqv
Turbo timer hks
So I can at idle rev the motor without anything happening, and also, there is no codes.
When I had hit fuel cut while driving, a cel would light up, but then turn off 2 seconds later.
What can I do to get rid of this!
I do have a safc2, but not installed yet. Is this the problem? Then it would need to get dynod tuned.
Also, I have a aem wideband, just not hooked up really. What I mean by that is, I need to re wire it. I have turned it on at idle, and its reading ok.
I checked for boost leaks, and none found as well.
Any help would be great!
My mods:
57 ct26
560 inj
Lexus Afm
Afpr set to 40
320 lph fuel pump
J tube delete
Spearco ic
Hallman bc
Hks ssqv
Turbo timer hks
