fuel cut on stock engine with DDP?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
i'll see if i have clamps on that hose... all of my hoses are NEW.
maybe i'll just go take the shims out and slap the MBC on there and double check all of my clamps and see what happens...
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
I had the same problems when I first put my DDP on last year. Hit fuel cut in 2-5th gear. Took my shims off and the car could do 5th gear pulls no problem.
Fast forward to me taking the car out after storage this winter and I put on my HKS BOV. The car no longer only made 7/8psi it was going up to 13 without shims and fuel cutting in 3rd again. Checked the stock bypass I took off and sure enough it was shot. So now it appears that I have a problem with the wastegate opening. I will be checking how far it opens when I install the new accordian hose, and compressor to wastegate actuator vac line (I am hoping that is the problem since I don't want to take the DP off or worse yet have to port the wastegate). Only other thing could be that actuator itself but it seems to open in the same spot it always did (the ddp makes that real easy to hear).
Has anyone had problems with the stock CT and having to port it to have proper boost control? I was under the impression it would be abnormal for the BIC DDP to have the wastegate unable to fully open? The one cool thing is with the cars new found power it is really fun in first and second :)
also car currently has the apexi intake, stock IC, Cooleze hard pipes, no wastegate shims, and the straight 2.5" exhaust, the 3.5 is going on it this Friday hopefully. Had some fitment issues on the install.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
one thing i did do was port the hole a little bit, and smooth out all around it where it would "hit" and make sudden turns to try and smooth it out... but that was when i first rebuilt the engine 6-8months ago...
i still havent done a boost leak test, been too lazy/tired/stressed out about a lot of stuff...
i think im gonna "borrow" my friends wideband from his eclipse and see what im running as far as a/f wise... cause i get really shitty gas milage...
