Fuel cut... Lex AFM? need a good writeup
supraGhost
212
PA
Can anyone point me in the right direction?
i know fuel cut is at 1 bar. Is this limited by the ecu or something? i know i see a lot of people installing the lex afm (which btw doesnt search well lol) to get around this. does the sotck afm only read up to 14.7 psi and then just go "fuck to much air shuterdown"? or can it be modified? Sorry i just havent had a good writeup explaining why or how. How does tuning work with this then? sorry for noob questions. i just need a good read on this stuff.
thanks
Mario
56
st. paul
yea i had a thought like that a while ago what if we just hone the in side out a bit like maybe 2-5mm, but would this affect the honeycone sensor. i was told this wpuld be useless and dumb so i didn't try it. All though i wonder??? haha
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
not worth the risk of damaging the honeycomb. a lex afm can be found for less than $100 and ive seen 550s for sale here for around $300 from time to time
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
he doesnt need to HAVE the injectors with the LEXafm he can run without it if hes not trying to run past the fuel cut but if he is he can run a AFC or something to richen it up a bit
frontierguy25
968
TX
No you don't have to as long as you have an adjustable fuel pressure regulator and a walbro pump and some descent injectors. I've seen it done many times with stock injectors as long as you can tune it you will be ok. You might want to pick up a fuel computer soon as well like a SAFR or SAFC or MAFT Pro......
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
EXACTLY thanks for filling in the 2cents i forgot to add lolz
thats what im running a AFPR SAFC NEO and a lexi and i have noproblems
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
you should know that you wont see any gains with just the lex afm.... the whole point of getting one is so you can upgrade your injectors and turn up the boost
lexus AFM is safest with 550 injectors.
Also, DO NOT try to bore the stock AFM out. The lexus AFM and the stock AFM are both the same size in that portion of the AFM. It's the port underneith that allow un-metere air past that is larger.
Also, it's based on flow, not PSI...
grimreaper
2,180
Dallas
... using a fuel computer to tune 440's with the lex is going to be reverse engineering as well since you will "likely" be adding fuel
supraGhost
212
PA
so lets say i upgrade the turbo to a 57 trim or something which will flow more cfm at the same psi.... i will be able to run less psi than before without hitting fc?
you will hit fc at a lower psi than with stock turbo. i have a 57trim stock boost like 5-8 depending on temp and i dont hit fc with the adj screw on the stock afm screwed in a lil.
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
Well when your stock AFM goes out and you have a option to upgrade for cheap i went with it. more then probablly ill end up running some 550s but till then im totally happy with my performance
thevork
ShoarmaTeam Member
Just curious, When using the 440's with al lex-afm, how will normal driving be like? The s-afc can only ajust fuel consumption when the ecu is in open loop.
Most probably the Vf is maxed out completely. Won't normal driving and idling be lean as hell ?
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Just bump your fuel pressure up a few psi, I think stock is about 38 (vac dissconected) stick a multi meter on the diag box to get the Vf signal and bump the fuel pressure till the readings come back to 2.5v this should keep you closed loop fuling pretty close.
Then you put the Lex AFM electronics in the stock housing.
inbeforetheiblewupmyenginethread
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
LOLZ
if everyone is so adamit about me taking off the lex i will lol
but with my afpr safc and my walbro i dont see a problem
but to make everyone happy ill go snag one from my friend lol
