cnewingham said:my a/f's are reading 10. at wot so I am not hitting a lean condition. I am not going the maft pro route either as I have dealt with the original maft and for reason known to others I refuse to go maft. Lex/550's is tried and true and after that I will be going full standalone.
I do have an afpr set at 28psi hose connected so do you think I could up the pressure a bit to get me past fc?
Raising the fuel pressure will not help you where fuel cut is concerned.
The reason the Lex works is you are bypassing more air around the sensor and it's larger diameter. You are fooling the ECU into seeing less air than is actually being compressed and sent to the motor. The Lex will raise your FC to about 16 psi.
If you want to get more boost, you will have to go with a MAFT Pro or a stand alone EMS on a speed density set-up.
