Fuel cut and wideband o2 location
Suprasath
27
Toronto
As the title says I need to find out how to get rid off the fuel cut after 14psi. I have the maft pro hooked up and the afm is removed permanatly.
Also where to put the wideband o2 sensor on the exhaust. If any one has an idea just leave a msg
Thank you
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Once the MAFTPRO is installed there is no real good full proof way to get rid of fuel cut. The one way is to lean out the map. You want a steady drop from 14.7 to 11.5-11.8AFR from to 0psi to full boost.
Wideband needs to be atleast 14inches from the turbo in an upward pointing position were water cant sit in the sensor.
wide bands are not supposed to get mounted where the stock o2 is. somewhere around 12in so they dont get as hot.
