Hi, this is my first tech post, hope i'm doing everything according to hoyle.
I've got an 86.5 n/a automatic, 104,000 miles on the odo, and when its up to operating temp, and i'm cruising under light throttle, i get a quick "buck" or hesitation, then it's fine for awhile sometimes, sometimes not. If i vary my speed between 50 and 60 mph , never staying at one constant speed, it doesnt do it.
Sounds like a TPS? I purchased a new one and have adjusted it per tsrm specs and also tried my own adjustment wherein i set the idle switch to be very sensitive to throttle movement (trying to rule out the possibility of the idle switch being actuated under light throttle ,possibly cutting fuel).
When the described symptom occurs, i dont notice any fluctuation of the tachometer.
I am so frustrated with this car, and very hesitant to throw any more money at it without some solid diagnosis of the problem. Transmission fluid is clean, trans shifts very well, torque converter events seem correct according to throttle position, kickdown is beautiful. The engine performs great.
if its of any help to those who read this, here is a list of things i have done to the car:
new TPS
new coolant temp sensor
new O2 sensor
new distributor, cap, rotor, plugs, wires
new valve cover gaskets
new air filter
new fuel filter
added an intake elbow to replace mine that cracked
added an MSD streetfire ignition, blaster 2 coil, and 8910 tach adapter (problem existed before adding the aftermarket ignition)
No trouble codes reported for engine or transmission.
The only way i can seem to get the jerking activity to stop is to unplug the TPS, leaving me with poor performance and a barely functional transmission.
-I am forever indebted to anyone who can help me out here
new TPS
new O2 sensor
new air filter
new fuel filter
