Will the front sub-frame out of a N/A 87 fit into a turbo 90? I know the 89+ will fit into a pre 89, but I just want to double check that the reverse is also true before I start swapping out front sub-frames.
Adam
Adam
cjsupra90 said:yes, the brackets will swap without issue.
Can I ask why you are back dating so to speek?
IJ. said:Square mounts are better![]()
