I'm having trouble getting the nose piece (in front of the hood) off. I believe I need to take it off so that I can reattach an emblem (please correct me if I'm wrong here). I couldn't find anything on this in the TSRM.
It seems to be stuck where it attached to the fender. I took off two 10mm bolts on the left side under the left headlight but it still won't budge. When I look through the frame a bit I can see another bolt on the inside just above where the trim attaches, and I'm almost positive that it is what's holding the piece on at that corner. How can I get at that bolt? Am I going to have to take off the whole front bumper?
Pics for reference:
Need to put this:
Here:
And I'm stuck here (circled where I took out the two bolts):
Picture of area from behind partially disassembled headlight (arrow is pointing to where the bolt is I think I need to get to):
Picture from under the headlight toward left fender (circle and arrow have same meanings as above):
Pics for reference:
Need to put this:
Here:
