front facing intake
Zach
ECUMaster USA
Apr 6, 2005
375
TX
If I'm not mistaken I've seen manifolds for the Mk4 made by that same company where the casting was made with terribly contaminated metal. Even after polishing you could still see voids in the metal. It does look nice, but I'd hesitate to spend that kind of cash with an overseas company with no real history.
jdub
Feb 10, 2006
10,730
Valley of the Sun
^^^ LOL! That wasn't because of the welds or high boost. Nothing like a manifold full of LPG and a backfire to ruin your whole day! ;)
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
I'd like to see a turbo that can continuously feed that kind of pressure, and spool up at about 4k :biglaugh:
How much pressure would you say it took to cause that kind of carnage? at least 400 psi by the looks of it!
shaeff
Kurt is FTMFW x2!!!!
10
Around
haha, most people aren't IJ. ;)
what haven't you broken, ian? haha
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
IJ. said:
Zach: LOL funny part is that's where I bought the material for it
Until you do all your own machine work on your block, and head, AND create your OWN aluminium, there will always be a scapegoat, won't there? :biglaugh:
Jag: I'd guess a bit higher as it managed to blow the 2mm HKS Stopper between 3 cylinders as well :(
One thing I noticed on that intake was it drummed a bit at idle due to the intake pulses and in time would have failed along the lines of what Supra1 was suggesting.
Shaeff: Not a whole lot..... :(
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
wow i find this funny that thing will not fit its from japan brake booster on the wroung side and that sucker takes alot of room
strictlySupra
157
Canada
ffim sits quite a bit lower than the stock manifold. level with the ports actually in this application
should fit underneath the booster.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
So far I've only "hear" on here from one person that's tried to fit it and they've ran into the issue of the back hitting the brake booster. There are other brake boosters that will work on the supra that may allow enough room for it to fit if this is indeed the issue...
Ian, I just knew you were going to post up a pic of your blown FFIM when I read the post on them blowing ;)
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
IJ. said:
dtwsupra
21
michigan
Would like a ffim built for my 7mgte with all the factory connection.Can you please give me your price and how long it would take also do you take paypall or money order
