Scot;1220471 said:This is what the body shop recommended after my wife's car had some repairs done. Actually it all that she uses to put shine on the black 91. Any paint pros on here can comment one way or another.... Per 3M this contains no waxes or silicones and can be painted over. So this might "something" you can use while waiting for the cure... Again, I'll leave that open for the pros to comment on... A high speed buffer is not required either... which is a good thing...
http://solutions.3m.com/wps/portal/...S4K7_nid=T9KWJ03R3Pgs9NQK7NZ8TZglXQWM5FPVC6bl
This is what I was referring to as glaze,use a product along these lines to polish the clear.The sand scratches from 2000 grit are hard to get out with a glaze,you'll want to use an actual "buffing compound" for that (has a little grit to it),then follow up with the glaze to polish out swirl marks.
