Fresh out of the paint booth Updated! 10Feb2008
The1
Too poor to be here..:(
May 24, 2007
228
Austin, TX
Hey GTS, I'm loving the car almost as much as you...and not just because mine is nearly identical...lmao. Very clean car..
mkthree92
163
AL
Beautiful- looks great outside and in. Nice and mint. Where did you pick up that dash cover?
reklund5
46
Henderson, NV
So on my past couple of drives, I had noticed a bit of a pull and the smell of overheated brakes. It appears that my stock calipers were getting sticky, and the right caliper was stuck, which killed the pad and overheated the rotor. Here is my solution, thanks to AZP :biglaugh: My old Konig wheels wouldn't clear the calipers- the shape of the spoke is all wrong for brake upgrades. I only needed 5mm extra clearance, so I had a set of custom wheel spacers made by www.wheeladapter.com to gain some space. Some longer wheel studs, and the spacers, and it all fits!
jugodegolf
Phoenix,AZ, United States
Wow I don't think I saw the interior before. One of nicest burgandy interiors I've seen. shoot me a pm if you want some floormats/ my lady is making me some trunk mats. That brake kit is just what I want it gets expensive when it's x2. I better go check the money tree.
reklund5
46
Henderson, NV
The Marlin thrust washer is a one-off deal. It's just a cryo-treated stocker, but seems to be holding up a bit better. Also, there are additional oiling grooves machined into the washer to try and keep a little oil between it and first gear.
After breaking 2 others, I got smart and quit banging the gears so hard. I came to the realization that a Supra is NOT a 1/4 mile car, but rather a GT car, and drive it as such. Between the upgraded part and some more attentive driving habits, I haven't had any further trouble with the transmission....
Thanks for the offer on the floormats, but I have the originals in MINT condition in plastic out in the garage. I use the cheap rubber mats for everyday use...
Ryan
reklund5
46
Henderson, NV
It's not really a daily-driver at all anymore, but if I drive it to work, I don't want to stick my size 14 greasy boot all over my nice carpeted mats...
Let me know when you're in town for sure!
Ryan
shaeff
Kurt is FTMFW x2!!!!
11
Around
GT car for some, street murderer for others. ;)
i fall into the latter of the two categories.
