I finally got my swap finished to point where I can start it, and it wont start.
Details - all stck 89 7MGTE, ran when pulled from car, rebuilt, installed in 4runner. Original ECU+harness.
I have no fuel or spark. I have checked for power with the ignition set to "ON" at the following terminals on the ECU:
+B, +B1: both of these have power from the EFI relay (12v)
Batt: always hot (12v)
IG sw: on when the ignition is on (12v)
E01, E2, E1, E2: all grounded
When I turn on the ignotion to run, the EFI main relay closes, and the fuel pump turns on. The fuel pump stays on until I turn off the ignition. The fuel pump will also turn on with the EFI relay removed, if the starter is engaged (so both methods for turning on the fuel pump are functioning). I have fuel pressure at the rail.
The CEL illuminates when I have the ignition set to "RUN", and turns off while I am cranking. The engine cranks normal (sounds like it has compression). I did a compression test on cylinders 1 and 4, and both are at about 100PSI (keep in mind the engine is at 25 degrees F and has not had the rings seated).
The coil packs and engine block are grounded, and the coil packs are plugged in.
2 questions- is 100PSI ok for an engine that has not had the rings seated and is cold? What should I check next?
