I have a freshly build motor and it is burning a ton of oil. I had it running for maybe a hour and a half and its burned a qt of oil. The car isn't leaking any on the garage floor and the spark plugs are clean, so i don't believe its my rings or valve stems. I'm starting to think that the turbo seals might be bad? I'm doing a compression test later today and pulling the down-pipe to see if oil is in it, but any other advice?
