Crazybobmundo said:
Hey, do you remember how many freeze plugs there was on the engine total? I ordered 9, at toyota they told me its only 9 total but I counted the openings and there are about 11.
Any clue which ones are freeze plug openings, and How many there are?
Now if I remember correctly their sizes are as follows:
2@ 30mm on the left side
1@ 35mm in the back
7@ 40mm (3 on the left side & 4 on the right side)
1 flat dish like plug in the front.
11 total (which is comprised of 4 different plugs)
The block you bought originally came with a 7M crank.
It is the later year type (although I am not 100% sure that makes a difference...).
According to the Cygnus EPC, here is how they are from the earlier years to the later years:
Early years:
Later years:
EDIT - To add below:
I would recommend using FIPG when installing them.
I would also go with Toyota plugs as well for two reasons:
1) They are brass (if I remember correctly, which is better than galvanized steel).
2) They are on the money as far as sizing goes (as previously stated
Freeze Core Plugs
