ma71supraturbo said:Get em from Toyota. The ones off the shelf for the SBC are very close but aren't quite the same -- I forget who it was that recently popped a couple freeze plugs out on the dyno...
IJ. said:Jeff: Not sure there but here you can buy Metric plugs off the shelf, it's just the flat one behind the timing cover that's hard to find.
supralover2000 said:How many total freeze plugs are there??? I called toyota and the parts guy said that He counted 11.....
Depends on the year SL, my new GTE block has 2 more than my old NA block.supralover2000 said:How many total freeze plugs are there??? I called toyota and the parts guy said that He counted 11.....
Well, they are big plugs in your block that are supposed to blow out if your coolant freezes to prevent damage to your block. Of course, most people who let their coolant freeze don't realize it, and then drive the car - when the coolant melts, it promptly vomits out of the freeze plug hole until there is none left, then the engine overheats, the head warps, and the head gasket self destructs in sympathy.7M-GTE said:you can call me and idiot for not knowing... but what are freeze plugs... and what do they do...(I'm still learning the 7m and probably always will be...)
IJ. said:Depends on the year SL, my new GTE block has 2 more than my old NA block.
Not sure if this is normal but the NA Block has 2 big arse screw in plugs at the top rear side of the block whereas the new GTE doesn't.
IJ. said:DC: Thanks we were discussing this here the other night as all of the NA Blocks I have here have the screw in but both the GTE's I have are freeze plugs!
Interesting to hear the early GTE's are screw in as well!
