First off, the stock "freeze" plugs should last the entire life of the motor, through several rebuilds, if the cooling system is properly maintained, and should not be tampered with unless leaking or damaged.
They are high quality steel core plugs from the factory, and steel should be used exclusively, as brass is too soft, too succeptible to deformation and heat damage, and does not provide the necessary tension to remain effectively installed.
The front plug is specially installed at the factory and is extremely prone to failure if replaced. It is staked at the edges, a process rarely performed properly by local machinists.
Here are photos an improperly installed front core plug.
You can see how it is dimpled past center. It was driven in by a pointed object, which distorted the plug, but did not expand it into the opening.
Here is what the factory plug should look like. Slightly flattened in the middle, with swage marks around the edge.
The plugs do not need to be removed for any machining or cleaning.
This is an old-school rebuilding technique used on early hot-rods that came with notoriously poor quality OEM core plugs. Early domestic galvanized plugs were prone to rust and corrosion-related failures, and therefore, machine shops replaced them as a standard part of a complete rebuild.
This is NOT recomended on the 7M engine. Leave the plugs alone if they are still in good shape.
Let your builder/machinist know - DON'T TOUCH THE PLUGS!
Thankfully, my machinist has assumed liability for the installation, so I will be able to recover some of the loss, but be warned.....you might not be so lucky!
