FPR question
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Sup guys, i just hooked up a fpr on my buddys car and for some reason the pressure stays at 15psi nomatter what i do wether i tighten the adjuster or loosen it, do u think its a bad regulator, or maybe the way its hooked up.
the way i have it hooked up is i took my stock feed line off of the hard pipe, and connected a ss line to it connecting to the side of the regulator, and from the other side of the regulator to the fuel rail. does that sound normal, it just looked like common sence to me, i might be wrong though.
any help would be appreciated. thnx
-saif
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
line from fuel rail -> either side of the reg.... block off the other side of the reg you dont use. Bottom of reg -> stock return line.
Supracentral
10
willfish said:
what is the range that the psi should fall into ?
whats the norm ?
The base range is 33 to 40 psi (nominal) with the pressure line unplugged, I've even seen people go as low as 28.
15 is WAY too low.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Thnx guys, got it figured out, for some odd reason, there was a little ball pluggin the inside of the braided hose not letting an fuel pass through. dont ask me how it got there lol
-saif
