I'm not sure if these problems are related. Yesterday, before I drove to school, I bumped up my fuel pressure a couple psi (last base setting was 38 psi with vaccum), to richen up my upper rpm range. Everything was ok, went to class, came back to the car and it wouldn't start cause of my starter. I got a jump start, and just before I was going to get on the highway, I turned on my foglights, and things got dodgy. my afr went a little lean and the car wasn't responding like it usually does. I took a different route home so I could keep the load low. The afr's wavered between 15.5 and 16.3 at idle, steady and rythmically. under load they stayed pretty much the same, and when I took my foot off the gas to brake, afrs would drop to between 12.7 and 13. Car sputtered and bucked under light acceleration and the BOV would release air sometimes without taking my foot off the gas. Once I got home, and turned off the headlights and foglights, the idle changed, and the afr's steadied a bit. I opened the hood, and the FPR gauge was going crazy, the needled was bouncing between 20 and 25 psi. I pulled the vacuum and pinched the line with no change. Previously the needle never bounced, and i've never had fuel pressure that low. Did the jump start mess up something electronically, causing maybe the pump to go bad? could it be the computer? Could it be something wrong with the lighting?
