Found a SC300 2jz for $500, is that a good buy?
Zach
ECUMaster USA
Apr 6, 2005
375
TX
dok33 said:
I paid $250 for a 2jzge with 130k on it w/harness, ECU, and all the accessories. I've seen plenty from $250~$500 depending on mileage, just find a MKIV NA or SC owner that's doing a swap, they're usually happy just to get the NA engine out of their garage...
They're seriously taking over my shop, I should make a building out of 1uz's and NA 2j's. Anybody who wants to drive is more than free to come pick one up for cheap in North Texas.
Going rate seems to be $500 at ABSOLUTE max everywhere I've seen, you can probably pick one up for $300 within a week or two of looking.
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
Looking back, that's probably what I should have done. :( Oh well, GTE electronics are bad ass. :D
A lot of the guys I know personally are doing 2JZ-GE NA-T swaps because it is so much more affordable. Also, USDM GE engines are smog legal in CA.
Collin
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
soundwave2000 said:
would it really even matter if it na or not for people building it ground up? Aftermarket internals for turbos work on na 2js right?
The only problem I could see would be having to drill the oil feed pipe for the turbo that is unless its pre drilled from the factory. I would assume like the 7M that turbo and N/A blocks are the same casting.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
blocks are almost exactly the same, most people that make their 1jz 3.0 use a 2jzge bottom end and the internals will work. 500 is the average price for a 2jzge.... taken apart bottom ends range from 50$-250$ and the heads are even cheaper
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
Ive got an Aristo 2JZ-GTE for sale in BC. Willing to deliver to WA if thats what it takes to make the sale.
