Forged 1jz
tsuper92
supra addict
Apr 7, 2005
1,376
mass
most people do a 2jz bottom when they build one up.never heard of anybody doing the 1j block
Satan
Tampa
No and No....
Maybe if you look in the different DYNO-sections of common Supra sites, you may find a better answer.
I
itr206
Guest
JonnyRedline said:
my 1jz does 1,000lb/tq
Why do you bother answering? Nothing you say is ever technical whatsoever. ughhhh
Anyway, I have not seen one.
Supposedly there is a dude in FLA named Smiley laying down like 900+ whp on a stock motor and really simple fuel set up. But no one will ever get any info on it or pics or anything. So to me it is kinda like Bigfoot. I would need to see it to speak on it.
IMO , the motor should do just about anything a 2JZ could do. Its the same motor, except for the smaller stroke really.
People with the big HP usually put the 2J bottom end in because they want that displacement and easier to find bottom end parts for I guess.
Mehhh, same crap to me.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
smily in FL did 1200 HP on a stock 1jz but it blew up shortly after. aperently he's been hovering around the 1k mark for a while.
JCP
The Big Unit
Apr 6, 2006
128
Raleigh, NC
Well... seeing as you are buying a used motor.. it is quite possible that you may need to do some things to it... It depends on where you buy it as to how beaten it is... Replacing a few seals is a must in a 1jz swap.. but if you arent careful on where you buy your clip/motor then you may get a piece of shit.
In short... dont buy from any ole company on ebay.. there are a few companies on these very forums who can offer you a good quality clip/motor..
With all that in mind... to answer your question no I did not "rebuild" my 1jz upon install.
I
itr206
Guest
I didnt rebuild mine.
My compression was 185 straight across. No leaking oil or nothing. I do kick myself in the ass for not checking the turbos before install though.
They tend to be shit.
I did replace the clutch and found out when I toko the tranny off, it was a good idea, as it was rocked big time.
For shits and giggles I did the rear main seal and thats it really besides fresh fluids and new plugs.
Just do research and make sure the motor is tested by a trusted source.
Get from Jarco or Driftmotion and you will get a clean known to be tested motor everytime.
dont be cheap. if you are a typical MKIII owner, dont even bother as you will end up with problems.
turbodriz
mk3 onwer
Feb 25, 2006
471
newyork....N.c
I hear you bro. I already have a grip invested into the 7m. So I'm already prepared to spend more. I just want something that's going to give me about 500hp for know and when I'm ready build and go higher. I like the 2j and all , but to much is involved in that swap for me. I know that I would never want more than 800- 900hp so there is no need for 2j. I"ll probably never need that many ponied ether.
Jimmysmk3
79
Oakhurst, NJ
why do you care so much about what he says? and yes he does have a lot of technical answers in many threads if you search.
JCP
The Big Unit
Apr 6, 2006
128
Raleigh, NC
That would depend upon the condition of said used motor :p, but generaly a great idea to tear the motor down and forge it before shooting for the stars.
I
itr206
Guest
Becuase he is a fucking retard that worries about post count instead of actually answering questions. It gets on my nerves. Leave the bullshit remarks for OT sections or something. Since that is what he is good at.
I dont need to search. I have yet to date seen him post a single useful remark on either forums in the past 2 years.
I
itr206
Guest
IJ. said:
Used motor with bolton's to make 600+ = hand grenade
ignition key = the pin.....
I dont agree. but we are all entitled to an opinion I guess.
So you think MKIV guys are crazy making600-700whp on stock internals?
If it can handle it, why not
