For you low budget JZ single upgraders...
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Don't forget about the XSpower kit for $1299!
http://www.clubna-t.com/forums/showthread.php?t=2037
NEW!
1JZ kits
** $1299 Shipped **
T60 T3/T4 Hybrid turbocharger (.70AR Hot .81AR Cold, compressor: 4" inlet, 2.5" out Turbine: T3 in and 3" V-Band Out - no welding required)
12x24x3" polished aluminum front mount intercooler (optional sizes available)
1JZpolished stainless steel manifold
HKS style 40mm wastegate
polished stainless steel dump tube
Turbo XS style -OR- Blitz DD style blow off valve
4" polished stainless intake tube
3" v-band clamp kit
3" v-Band polished stainless down pipe with 02 bungs
Teflon and SS braided oil supply line, high temp drain lines & flanges
gaskets
turbo oil return plate (to oil pan)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
cactus_mole said:
This is the kit i'm going to get when I ever get going on my 2jz project. But I dont think i'm going to run that turbo.
IIRC, all marks kits come with a t61 or equivalent, and i havent seen anything negative on cna-t about them.
fstlane88
Single time!!
South FL
What could one get that kit for, just buying the following....
1JZ polished stainless steel manifold
3" v-band clamp kit
gaskets
bigaaron
4,692
Pomona, CA
www.driftmotion.com
How is being a complete hypocrite working out for you these days?
Ric said:
Any turbo made by: Garrett, Turbonetics, Precision, HKS, etc. No "Master Power, or T6x special ebay units.
Ric said:
etrash. Get something thats not a converted car radiator.
Ric said:
Not everything can be diamonds, but if your putting effort into a turbo upgrade, why get a shitty turbo and waste $$?
If you take the turbo out, there isn't more then $800 worth of stuff in that kit, and that's not a $500 turbo.
OneJoeZee
Retired Post Whore
aboard the Argama
I wasn't gonna say it but I'm glad I'm not the only one who noticed.:biglaugh:
The funniest part will be the cop-out excuse he comes up with to cover his ass. ;)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I bet Ric is a not a bad guy in person. There's just some weird agenda behind most of what he posts that is almost impossible to figure out, because it seems to vary on a daily basis. If he wasn't so outspoken against ebay items, it wouldn't be so bad when he tries to help somebody sell them. The turbo kit honestly doesn't look bad, it's the least expensive kit that's fairly complete. The turbo can be re-balanced and upgraded to a 360deg thrust bearing, and you end up with a fairly decent setup for under $1600. The mistake some people make is thinking that that kit is just going to bolt right up with just a socket set and a screw driver.
Boostage
323
Florida
RIC for the record Master power isnt a shitty chinese ebay turbo, they are manufacturered in Brazil with 100% garret internals.they just make their own spec compressor and exhuast housings. same thing with precision turbos. garret internals but their own housings.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Exactly, I wasn't going to get into it tho.
csnow
Matthew 6:33
Palm Bay, FL
Dang, if I would have saw that kit I would have saved at least 6k on my 2J swap. Why did I ever get rid of my 1J. All that is needed to complete this kit is a Texas Instruments solar powered ECU with a built in calculator. I would have been all over this quality setup :rofl:
