For those using a w58
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
What clutch are you guys using and how much power are you making? I am about to swap a 7mgte and use my w58 but i have searched and cant find any info on which clutch i should use. I know i have to use a 7mge push type clutch but which one is right for me? I plan to keep the motor basically stock for a while and maybe up the boost to around 11 or 12 psi eventually. I have a 3" dp and 2.5" cat back and an air filter but other than that it is stock. (Stock inter cooler and piping etc) Any suggestions are welcome!
jake breyck
33
fl
Im useing a custom made 6 puck unsprung metal pads on a 1800lb prssure plate on my 1uz supra, this setup will stand up to about 500 ft/lbs. way more then your proposing.
shaeff
Kurt is FTMFW x2!!!!
10
Around
I was running about 300rwhp/300tq through my w58 w/ a Fidanza Lightweight Flywheel and Clutchmasters Stage 3 full face carbon/kevlar disc clutch. Pedal felt exactly like stock, absolutely no chatter, feels excellent.
Haven't had the car on the road in a while. I ran it like that for quite some time, and I have a very, very heavy right foot, and a very aggressive left foot. ;)
Fuzz420
Are U Here 2 take My Baby
Im currently running a spec stage 3+,fidanza flywheel, id say im around 340whp.It feels like my old stock setup but i do get some low rpm chatter especially when the clutch is hot and sticky. I think you will be hard pressed to find a clutch for the w-58 that holds power under $200
Scruggs86.5T
298
Slidell, LA
sounds like i am running about the same setup as what you are planning on running, i have a clutchmasters stage 2 with the stock flywheel(w58), it holds fine and there is no chatter whatsoever. not sure what its rated or price.
shaeff
10
Around
Oh, just for the record, I only dyno'd on my stock CT-26 and got the above numbers @ 15psi. I later upgraded to a single BB 60mm CT-26 from MDC, and at 15psi my car absolutely screamed. Just guessing, but with the amount of power I had before the new turbo and after, I'd say it was at least a 70-80rwhp gain. That would put me near 400rwhp.
Clutch held just fine.
natedogr
296
Chatham, Va
i've got a centerforce dual friction clutch. i'm running around 11psi right now with a 3" turbo back exhaust, ic pipes, and intake. the clutch holds great and i'm only planning on making a little over 300hp with it. the clutch is only $350 on some sites.
87tomanymods
87tomanymods
Oct 25, 2008
193
lansdale
dont use the centerforce dual friction i have one on a 7mge non turbo w/ the w58 and i have completely grenaded it to smitherines twice the only reason i keep using it is because they keep warantying it for free the last one only got like 2000 miles on it before turning into a pile of dust in my opinion act is the best hands down for any street aplication
dumbo
1,911
Albera, Too Far North
wow how you driving it.
I apparently have a "centreforce";not sure the model. I put tons of hard driving it when i was na held good. Turbo'ed her and so far so good, even HARDER driving and no slippage/smells, feels strong. soon to find out how she's gonna take to 11-13PSI :evil2::evil2:
dumbo
1,911
87tomanymods;1227420 said:
both times it happened while speed shifting into 2nd gear maby cause of the 4.3 rear gears and i have meaty rear tires it would chirp the gear then byby clutch
by speed shifting do you mean not letting off the gas??
