All of the video's with the Black MK2 , drifting or drag racing , has this turbo on it.
http://youtube.com/user/pimptrizkit
i didn't port the waste gate, and im having problems keeping it from over boosting, well.
i dont have my boost controler on, and running on the stock waste gate, she'll hold 7psi till about 4.5k and after that jump to 10-12, then by 5.5 im nailing 17-20 psi.
i didn't realize i had this problem till i dynoed last week.
i didn't post nothing major since im unhappy with the numbers.
i had a stock pump in the car and should have swapped out the pump before i went.
i made 335whp,333ftlbs
the run's say max boost of 17psi, but i didn't make any more power after 10psi since it was leaning out.
that and the CEL is on since the ecu temp sensor broke a wire, so it could affect power.
the reason i said i wasn't happy cause i only made 10whp and 20ftlbs of torque more then the stock turbo at 12psi witch is about where this set up started running lean.
i have the walbro in tank now, and will dyno this week or in a few weeks @ supra nationals. so hopefully i'll be proud of those numbers.
