Poodles;1356337 said:The clear plastic is attacked by UV. They put a caoting on them to stop the UV from getting to it (basicly a clearcoat). Coating gets chipped, UV gets in and starts attacking the plastic and oxidizing it.
It can be polished out and then re cleared.
Or it could just be condensation on the inside, but I doubt it...
oldsking;1356347 said:Yeah man UV damage, damn sunlight!
ms07s;1356612 said:I have fixed several plastic lenses.
What I use:
one can of clearcoat
1000 & 1500 grit sand paper
a surface prep agent to remove greese wax ect that is plastic safe
cloth Buffer wheel for a drill or a high speed buffer
3M compound
Temp fix:
Buff it out with the drill and 3M coumpound, may last a few days or a few months.
Hardcore fix:
Remove lense, wetsand surface with 1000grit
use surface prep agent with a lent free cloth
Apply clear as per can directions
wait 3-6 hours
wetsand with 1000 to remove any imperfections
do a 2nd coat of clear
wait a day
wetsand with 1500 till uniform dull
Apply 3m compound with drill or buffer taking care not to go too fast.
Typicaly last a few years depending on if you wax and hand wash your car.
ms07s;1356626 said:You don't, you just do the outside. You remove the part from the car to eliminate overspray issues.
ms07s;1356629 said:Some people remove the outer lense with ovens and heat guns, but as you used alcohol in the lense it may have softened the plastic to the point it will just break when you attempt that process. If the lense is getting moisture in it, it has seal or ventalation issues
ms07s;1356640 said:May just be time for a new set. It's only ~$60 for a set.
