Studio1 said:
I had water getting in around the rear hatch as well, so set about trying to stop it. First I removed the spoiler, used silicon and sealed up every bolt hole plus siliconed under the black rubber "washers" that go between the spoiler and the hatch, then re-installed the spoiler. Next I removed the wiper arm, motor and bushing - cleaned them all up and re-installed with silicone around all that. Next I removed the trim around the bottom of the glass, cleaned the gutter out and put a donut of silicone around each bolt hole. Re-installed the trim. Waited for a rainy day. Hatch still leaks! Damn it all! The water is pooling up inside the big plastic trim on the inside of the hatch. I am damned if I know how it is getting in now.
This is
EXACTLY the situation I have. I have intended to do all the sealing up you did and have already done the wiper arm one. Now it sounds like the rest of them are not it either
Let me know if you get yours fixed.
Update with fix 11-6-8
Water in Hatch Trim
I did all the suspects - spoiler trim, wiper motor, window.
I also had water getting into my right tail light and did the seals for them.
After sitting on my new
hatch seal for a few month, I finally installed it.
Last night we had a deluge of the sort I should have received a shower when I open the hatch this morning.
No Water In Hatch Trim !!!
or the tail light.
not really worth making a new thread but wanted to update this so I could refer others to it in the future.
