Fog Light
89supra884
170
chicago
well if you are facing the car it is the right bulb, and for some odd reason it keeps going out. i just replaced them a couple months ago, the left one is fine, but the right one keeps going out.
any ideas......
thanks
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Interesting... Not sure why it would repeatedly burn out. Have you done anything with the wiring? Rewire of any sort? You could measure the voltage at the bulb to see if it is for some odd reason too high. :dunno:
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
grounds and corrosion..
take the fog lights out, and remove the rubber boot.
9 times out of 10, the metal piece is full of corrosion, looks very similar to battery posts with all the shit on them..
clean them up, and remember if you ever touch the bulb, wipe them off immediately with a little alcohol wipe..
TomFraser
and grease it up with bulb grease to prevent corrosion in the future
