MROsborne;1454250 said:I'm using one of the 3 switches on the left side of the steering wheel as my foglight on/off switch.is it possible to convert the lights to HIDs?
Mk3Tmoney;1454263 said:How was the wiring done for on that?
Drake69;1454989 said:You know what I'd like to see? An actual list of bulbs by code and SuperLED's replacement bulbs beside them. For ALL lights on the Supra. If there was a list by bulb then you could pick and choose what bulbs you wanted to replace, like dash lighting (I know, good thing there's a tech page on that!!!), exterior lighting, headlight/taillight/center LED/foglight replacements, dome lights/trim panel lights, side markers, etc. Also, a caveat on which replacements would require special work to replace, such as soldering and such. This would give us a common frame of reference for improving visibility and looks to our cars.
Just a thought?
CRE;1455038 said:Do a search for SupraRX7Nut's comprehensive lighting thread.
Drake69 said:...like dash lighting (I know, good thing there's a tech page on that!!!)
Drake69;1455044 said:Yup, had forgotten the name of the author but knew it was out there, thanks.
That writeup has the headlamps, but not the taillamps, spoiler LED, side markers, turn signals, and other exterior lighting included.
Poodles;1455072 said:Yep, but are you sure they're burnt out? The rivets are known to loosen up and loose connection (usually resulting in them not coming on when the doors are opened, but could also cause them to not work with the buttons as well).
Put your fingers in at the front on both sides of the arm that comes down to the mirror and pull (hard). Helps to pull forward a bit as well.
On the note of what works were, with LED's a LOT is up to personal preferance or different brands. While you could just cross referance the original bulbs, the way LED bulbs work can cause issues with not lighting things up enough or not being at the right angle to be used in the location. See what IJ did for his tail lights in his build thread for what I mean on preferance, as he added a bunch of lights to get a nice even spread, while others may think it's fine with one.
