FML bought a Evergreen gasket set plz help!
Setsuko37
95
Canal Winchester ohio
so got my 87 supra, 7mge, w58 and knew it needed rebuilding the gaskets are the nicest material but most of the ones are for low pressure areas but the head gasket is a POS everyone on the fourms says theyll blow befor your next oil change but quick question im NA so will the gasket really be under as much pressure as the turbo 7m's who have had evergreen automotive HG's that blew will my stock 7m blow it or yes but itll last longer then it would if it was on GTE setup?
bioskyline
1,236
powell river bc
theres still crap even in a GE application. do a goole seach and they dont last in any motor. the acura, miata, prelude, and even in toy trucks all say they failed within 2 weeks of install. a fel-pro, victor, or OEM would be a much better bet.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Get a Toyota gasket. Well worth the $80.
And try writing as if you're going to turn it into your English teacher. It's difficult to understand parts of your paragraph because you don't use any punctuation. :)
Sent from my ADR6400L using Tapatalk
