flywheel bolts broken
Another MkIII
697
Chicago
Seriously, get some ARP bolts, or at least a set of OEM's. You can get OEM's for like $12. And ditch the lightweight crank pulley and get a balancer. Resurface the flywheel and if its safe to use, reuse it, otherwise replace it. And lastly, get a clutch kit since you got it this far apart.
-AM3
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
OEMS are 46$ in canada. Get ARPS they are 30 $ form JRP if you are in QC city you want the ones for a 4ag-ge.
You need new bolts, the ones that you have are garbage home hardware crap.
i recommend a 6 puck disc or a full face fermaic. Call euro drive in Toronto, they can get you a disc for 200 Canadian, just send your old one.
QuebecmkIII
50
quebec
Yes but before replace all of that, I have a broken bolt in the crank, like 1/4'' inside... That a piece of shit.
I need to found a reputable man in my area because I don't want to remove the crank!
anonymic
11
Shippensburg, PA
Get a set of easyouts. With those cheap bolts you'll have no problem getting it out. Drill in the center of the bolt then run the easyout into the hole and the bolt will come out.
