Poodles;1631736 said:For power steering you do NOT use power steering fluid, you use ATF.
toyota specs says to use ATF, it says right on the resi cap too. the rack must need an additive thats in ATF but not in PS fluid.Reiketsukan;1631857 said:Really? I'm not disputing you, but this is the first I've heard of doing this. Could you explain why you'd do that? And which ATF is supposed to be used?
