Fluid recommendations?
salomon68
welkin
Feb 5, 2007
91
Knoxville
I've searched but didn't find a thread on this. The rebuilt engine is in and running. Installed new calipers, rotors and ss lines. I need to start putting fluids in. What do any of you recommend for brake and power steering fluid?
Reiketsukan
Jack of All Trades
Apr 13, 2009
288
United States
Poodles;1631736 said:
For power steering you do NOT use power steering fluid, you use ATF.
Really? I'm not disputing you, but this is the first I've heard of doing this. Could you explain why you'd do that? And which ATF is supposed to be used?
barkz
363
Afghanistan
toyota specs says to use ATF, it says right on the resi cap too. the rack must need an additive thats in ATF but not in PS fluid.
