first time changing suspension, quick question
d_block.5
51
OC, New York
I just got a set of JIC coilovers in the mail the other day, i'm in the process of installing them now and got my front suspension out, this is my first time installing coilovers, and was wondering if the shorter or longer ones are to be installed in the front, THANKS!
americanjebus
Mr. Evergreen
wa.
^ thats great but the coilover should usually have that tab anyway, look at the ones you just took off.
Front ones are usually longer and narrower while the rear ones are usually shorter and wider in diameter.
foreground fronts
background rears
d_block.5
51
OC, New York
neither coilovers have the abs tab, the smaller mount up to the front is that abnormal?
i put it on pause til tommorow when toyota opens so i can get new break pads
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
d_block.5;966922 said:
i got it, the height of the coilover needed to be adjusted to get it in there, thanks for the heads up fellas
Have someone stand on the brake rotor. Make sure you jack up the whole front and whole rear when you do it as well. Makes it 10x easier.
