first time at the dragstrip.
catback
bitterville
joliroger4;1038461 said:
You're AVC-R is hooked up all wrong. You tee out the compressor housing and hit the NC port on the solenoid and the side port on the wastegate. COM on the solenoid goes to the other port on the wastegate. NO is not used and should remain open.
Page 44:
http://www.apexi-usa.com/pdf/productDocumentation/200.pdf
i've searched forever for that...:biglaugh: thanks!!!
thats why i was pissed at the search function.
it seems to run better now, but 4th and 5th gear feel weird, i hit full boost and doesnt pull anymore, split second goes by and fuel cut!! WTF
why does it boost and feel perfect from 1st through 3rd gear and totally change for 4th and 5th???
