First pics of new rims mounted. no 56k
Sawbladz
1,727
Oshawa, ON, CA
I love my offsets because they are as fluch with the fenders as possible without major rubbing issues. Even as they sit I have rubbed a few times entering parking lots. I will have the roll the fenders because the next set of tires will be at least a 235 in the front.
This is about right in my books.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
Man, those are great looking rims on a MkIII!:boink: :yumyum: Do the fronts clear big brakes though? The flat spokes makes them look pretty aggressive! Are you gonna' eventually run 235's (f) & 275's in the rear?
Sawbladz
1,727
Oshawa, ON, CA
Yup, those are the next set of tires I buy. I'm running 255's in the rear cause they were free and 225 because I wasn't sure if 235's would fit with a +25 offset. Now that I know they will (after some slight rolling), my next set will be 235/275 with BFG KD's all around.
I would imagine they would clear a big brake kit. The spokes are very flat on the back and seem to have alot of extra clearance for the stock calipers. I will have to test fit them on a car with a BBK to be sure.
Sawbladz
1,727
Oshawa, ON, CA
Datsrboi said:
Dam so you are rubbing on those. I hate rubbing :(
Ive had a blow before because of a rub so maybe it frieks me out when I go wheel and tire shopping.
I hate rubbing too. They rubbed only once when I wall pulling into a parking lot at 3/4 lock. With a very mild roll of the lip I have no doubt I can fit 235's if not 245's.
The muffler is a Maganflow that was modified by Raptor Racing. It comes 2.25" inlet and gets enlarged to 3". Flows well and sounds great.
NgoFcukinWay
Formerly Got Boost?
Apr 3, 2005
493
Houston, Tx
Sounds good. Bummerz that it started out as a 2.25" inlet though. So you had Raptor Racing bore it out from the original 2.25" to 3"? Sounds like a plan. Have any pics and a sound clip of it?
