Update. Fixed my throttle cable problem with the use of some big ass spacers
And now the engine is finally starting to enter the final stages. With the turbo elbow and v-band welded its almost ready for the final bolt on
The turbine housing just needs to be coated and then the turbo side of thing should be done. Then its wiring, vacuum lines, and a coolant res. Then hopefully the first start up... After that its going to get babied down to my Dad's work to get an exhaust, wastegate dump, and intercooler pipes on the turbo side all fabricated.
Then there is a airfield drag event on the 8th. Not holding my breath to make it to that one but if all goes well it should be ready to go just in time for summer at the very least :biglaugh:
