Hey guys, I am currently putting the final touches on a rebuild that has been sitting in the garage for over two months. I have replaced the following:
Main and Rod Bearings
Piston Rings
All gaskets including valve seals
HKS 1.2mm Bead Head Gasket
ARP Head Bolts
It is a 7MG-TE egine, and I got the HKS EVC to control boost. Daily drive will be at stock boost but for race I have been told I should be safe at 14 psi.
I have a few questions to help me complete everything.
1. To what specs would you torque the head bolts with the ARP bolts, if I plan to run max boost?
2. How should I set the timing, if I plan to run at stock boost most of the time, but I want to be prepared for 14 psi?
3. If there is anything that I am overlooking, please enlighten me..
I really appreciate your input.
Thanks.
Delmer.
Piston Rings
ARP Head Bolts
Thanks.
Delmer.
