Finished My Twin Turbo Supra (7M) Last Night
liukc
Twin Turbo 7m
Phoenix, AZ
projectsupra said:
Looks awesome, those aluminum welds could have been better. What manifold is that? It looks exactly like my Trust TD top/bottom manifold but with T3/T4 flanges? Can't wait to see it run!
It started out as a Blitz manifold but after a lot of welding I consider it my custom manifold. I use T25 flanges.
liukc
Twin Turbo 7m
Phoenix, AZ
Rajunz said:
That's really cool..................Are you planning on running some sort of air filters? You could probably sandwich a similar oiled cotton material like a K&N between 2 of those screens. Just a thought, it looks like space is a premium.
Great job, post more pics when available.
I want to run a filter for the top turbo, but no filter (or a very discrete one) for the bottom turbo. I want it to eventually look like a single turbo car.
liukc
Twin Turbo 7m
Phoenix, AZ
MassSupra89 said:
Thats awesome.
I thought the same from the first picture of only 1 visible turbo, then I was like "ooooo sneaky"
Can't wait for vids and dyno?
My goal was to be a little sneaky with the turbos. I am dynoing the car tomorrow night. I need to spend all day today getting really familiar with the AEM EMS.
liukc
Twin Turbo 7m
Phoenix, AZ
Bondango said:
yeah agreed, looks a brillaint job - and a headache to do - more pics!! :icon_bigg
To assembly the whole thing is a pain in the a**. I needed about 15 different "custom" wrenches to assemble everything.
born2drv
1,199
Burbank, CA
are the turbos identical? will they spool up together or seperately? would like to see more pics of the manifold also, if possible.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
just wait til i unload with my triple turbo setup. ive got them hidden in the spare tire well. bolted around the center, they feed each other turning the entire spare tire space into one giant compressor. shift - psshaww!
liukc
Twin Turbo 7m
Phoenix, AZ
rumptis said:
sorry if this had been asked and I missed it...but what is your setup besides having twins?
I'd like to note that all fabrication and assembly was done by myself. This means everything from welding to milling and surface grinding. Unfortunately I had no sponsors so it took an extra long amount of time to complete (>2 years I think)
Exhaust: 2x HKS GT2835R, Tial 46 mm WG, custom downpipe & exhaust (SS304), modified blitz manifold, AEM UEGO Wideband o2
Intake: 2jz intake mani, 2jz tb, garrett 24x4.5x12 intercooler with custom 3" piping.
Fuel: 720cc injectors, dual walbros (will most likely change this later because this was from my old setup), sx pressure regulator, AEM EMS
Suspension: Cusco Comp Zeros, JIC A-Arms (Upper), 14" front brakes with Wilwood GNIII calipers, MKIV rear brake setup, Volk TE-37s
Engine Internals: I don't want to give everything away but I do have a set of blitz cams and some other good stuff.
liukc
Twin Turbo 7m
Phoenix, AZ
The turbos are identical, they will stool simultaneously (in parallel). I will try and take some pictures later but it is almost impossible to see anything. Runners 1-3 feed the first turbo and runners 4-6 feed the bottom turbo. The downpipes join together by the transmission.
miekedmr
mkiii in hibernation
Jul 12, 2005
513
Upstate NY
The best upgrade you could do from here is adapt it to spool sequentially... which is kind of the point of twins on an inline motor.
Either way it looks like a lot of work and I hope you enjoy it!
OneJoeZee
Retired Post Whore
aboard the Argama
sequential setup isn't the reason to put twins on an inline motor.
it's not that easy to just make a TT kit into sequential. Would take a new manifold and some sort of electrical control. Lot of extra lines and valves and stuff
anyway. that engine is really cool...
miekedmr
Jul 12, 2005
513
Upstate NY
It's not? Maybe I'm missing something...
Is there a production parallel TT inline motor? (really asking, I don't know)
As far as converting it to sequential, all you'd REALLY need is:
  • A cutout plate after turbo #2, blocking its exhaust until #1 spools and makes positive pressure in the intake manifold. (EGCV)
  • Another valve of some kind on the compressor side of turbo #2, to prevent it from opening to the rest of the intake until it's up to the same pressure. (IACV)
Of course I'm sure there are good reasons for the smaller "prespool" exhaust gas bypass valve and the reed valve that toyota uses.
I kind of think you could just put a very small pipe going from before the EGCV on the #2 downpipe over to the #1 downpipe and just let #2 have a tiny bit of "prespool" all the time, as a substitute for the bypass valve. The reed valve is simple...
and who says you need electronic control??
