finished for now!!!
alloyguitar
it's legal, i swear...
knoxville, tennessee
IJ.;1201141 said:
The Hi strength Steel used in car bodies anneals around 700c (this is why you're NOT meant to use oxy welding gear as the heat affected zone is so large)
Doesn't take a huge fire to generate 700c :nono:
Personal preference I'd NEVER reuse a burnt shell but that's just me.
That's exactly what I was thinking. It's not the temperature that it melts at that matters...
...once the molecules spread out, it loses most of the strength.
Have to laugh at the guys that "should" know better saying "yeah it'll be fine blah blah blah" ;)
As I said before it's just a personal preference based on what I know of metallurgy.
alloyguitar
Yeah, I'm no expert at it. I mean, I took a metal working class when I was in middle school, and do a lot of welding/fabrication (exhausts and such), but as far as something like a frame is concerned, just knowing that it could be damaged would worry me...
...I'm weird like that.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
In my opinion, unless the fire burned for a sustained period of time, the frame is fine, especially if no warping of the steel occurred. Plus, the typical locations a fire will impinge the car body are not strengthening members anyhow.
The kinetics of steel annealing are such that it takes several hours at 700C+ temperatures to fully anneal a cold worked steel. Unless there is a thick iron oxide scale on the steel, formed by prolonged exposure to high temperatures (i.e. no sign of burned paint), it is unlikely that it is has been significantly damaged.
It also has nothing to do with "molecules spreading out". (puts on science hat) The initial loss of strength of fire damaged steel is associated with the recovery of dislocations, spherodization of the cementite phase, and the segregation of alloying elements. As any of the higher-strength steel panels are likely low carbon microalloyed steel, the loss of strength begins to be dominated by the movement and segregation of the alloying elements (not the cementite spherodization), which, if I remember correctly, is not a rapid process by any means.
