Hi
I had every problem in the world before i got it right.
with the risk of sounding like a real dumbass ill write them all,cut and try really...
first of,cable broke.i fixed it,Mind you car is an 88 so the back sensor got a little demolished.no problem,made a little wire so it was without the connector,only wire came out of the sensor.
still no good.
well hell,check ecu plugs,found out that the pins have mooved while ive checked and measured resistance,ok bend then back.
still no good.
ok,change wire again.
nope and it still cant hear the sensor.
well fuck it,moved the rear sensor to an identical threaded plug in the middle of the block,yes I know not the right place but this shit was getting to me,so I had all the shit i could handle.placed a faultless ks and made the wire end plug in the correct form for it to fit on.no shit Einstein it worked after a year of headache.
I tried also changing ecu sensor and every fucking thing.man I was happy after all this.
Maybe its like dr jonez shortly said:"rewire it correctly"
Pissed me of but he's right
nothing else should disturb it's functions
